Aquaroll and water pump
I suppose you all do simular but i have never seen you do it.It came to me when the tank was empty and had to take out the Thames Whale pump, did not want to put it on the grass ,so got an empty mineral water bottle, cut the narrow end and put the pump inside so it is kept clean between reflling tank. Simple?.
Good idea, I'll put that in my little black book.
Our current pump has a 'clip' area on the plug end, where the pipe slots in to stop it dangling on the floor.
But it's worth noting in case we have to buy a replacement that hasn't got the clip.
No
I use the clip on the housing to clip the pipe up and it hangs the head in the air. But I suppose until you see it you probably do no realise thats how it works
I have 2 aqua rolls, so when one is empty. I slide it over a bit then put the full one into position and plop the pump straight in.
I have seen proper little pump bags that fit on the side of the van somewhere.
Is there no end to useless gadgets !
