Apr 1, 2025
17
10
I've just bought a Swift Challenger 530 (2022) and am in the process of changing my caravan insurance.
One question the insurer asked (on line) was if the van had ATC. I automatically said it did, as I thought all newish vans had it as standard.
My last van, an Elddis had an indicator on the A frame and when I hooked that van up to my car, the ATC cranked up.
However, my Swift doesn't have any indicator on the A frame and there is no noise when I hook it up to my tow car.
As I want my details to be correct and don't want any issues for the insurer to wriggle out of in case I need them, how do I know if ATC is fitted?
Thanks in advance.
Sep 4, 2011
388
178
18,735
You will have an LED on the A frame and when you plug in car will hear it set itself. But I doubt your caravan has it unless you have a dealer Special which had them as standard fit. Dealer specials also have different Decals than standard Challegers.
Apr 1, 2025
17
10
Thanks Birdman101.
I thought that to be the case.
Honesty the best policy with insurers.
Will refill the online form reflecting such.
Reactions: Jcloughie
2,461
As the Chalenger’s are high on Swifts range I would have thought they would have ATC, so I looked at their current specification and indeed they do. I would have thought the same was true of a 2022 model.
2,461
They came as an option some do some didn't
That surprises me, both the Bailey and Lunar vans I purchased it came as standard. And the spec on the current Chalenger shows it is standard. Perhaps it was optional in 2022.
2,020
I’m surprised that the OP isn’t certain of whether ATC is fitted or not. They are not difficult to identify viz:
I am in the same boat; wouldn’t recognise one of them if it tapped me on the shoulder and said hello I am your ATC gizmo. 😀I only know we have one because it was in the sales spec and there is a little light marked ATC.
2,431
Looking at this with interest we have been looking at a Bailey Caravan range are they standard on them, but we will not be towing but might be going seasonal .
2,020
If you are not towing you won’t need one! You will probably choose based on layout and internal specs, so I wouldn’t worry about it. Good luck in your search.
Reactions: Beachball
2,431
Thanks Mel the Unicorn looking more our thing because the fixed bed is big in dimensions .
Apr 20, 2009
5,621
1,025
You "bouncing back" into the caravan world Beachball?
