- Jan 19, 2007
- 11
- 0
- 0
I had also meant to say that the auto box makes for a safer drive in that you can concentrate 100% on the job in hand; even if changing gear is an almost subconscious activity it is nevertheless and additional demand best avoided under critical conditions.If your thinking of a vehicle with marginal power then it has to be a manual as even more power is lost through an auto box. Also the human brain is potentially able to better exploit gear selection and include prediction of hills etc. The manual also helps if the braking is marginal [this is likely to be the case with a underpowered vehicle anyway]. The manual is also better for ultra fine control such as needed for hitching up on a soft field.
If the vehicle has plenty of power for the job then an auto makes by far the better choice on grounds of refinement and a more relaxing drive thus easing driver fatigue and enabling proper use of cruise control [one where gear changing is encountered].
The auto will however in most cases use between 10 and 15% more fuel whilst towing but not be so relatively inefficient solo.
Just to clarify here I am talking about autos with hydrodynamic fluid couplings, I have no knowledge of the variable drive types.
My choice is without doubt plenty of power and an auto diesel and is based on a lifetime of towing.
Hi All, What is the right kerbweight for 2000/2001 Freelander auto, can't find it anywhere, keep getting the manual kerbweigh of 1620 for the freelander, is this right, Thanks TrevorWe've towed with auto's for about twenty years, even our old 2 litre Volvo estate was quite capable when we moved to a twin axle van and hapily towed with 5 on board and all our kit for 4-5 weeks in France and Italy.
The Volvo's had a 4 speed box with 4th descriced as overdrive with, Volvo suggested using 3rd when towing to prevent the box hunting between 2 and 4. In the 4 years we had the car we only ever set it in 3 twice I seem to remeber, the car was quite happy and economic towing using all 4 gear settings.
Ten plus years on and any 2 ltr or bigger car should cope well with a sensibly matched caravan. The conventional autos have a torque converter that beats using a clutch hands down. On slippery hill starts or even in the Alps or stick in hilly town traffic its auto every time. Providing you fit a cooler if needed you should get 120000 mile plus reliability from the Auto like we have.
Ah, Brandy is having that magical effect, perhaps I should stop now...You must have noticed them Frank, they are the ones driving "past" the petrol stations. Still, bet you have a lot of nectar points.....
Was that too confrontational?
