Award daystar - window spares/seal
Jan 13, 2008
14
Hi
anyone know where we could get new window seals for our 1989 Daystar. we cleaned & polished ready for the season, but now have water ingress, that appears to be coming in around the seals on the outer 2 front windows. One side worse than the other. We have removed 1 & re-sealed with rubber-mastik, which has improveved, but not resolved the problem. Think we may need new seals, or if anyone has any advice, would be greatly appreciated.
Derryck
936
Try Seals Direct: http://www.sealsdirect.co.uk/bbCMS/bbCMSrenderPage.asp
You will need to measure the width of the ones you have, and the total length you require as it is sold by the metre.
Make sure you order more than the minimum you need to allow for cutting.
May also be worth getting new infill strip too, and make sure you allow for at least a 6 inch overlap on each window to allow for shrinkage over time.
