You will get a better response if you post this kind of query in 'Equipment & Accessories', but I may be able to help you.
The handbook should tell you the correct awning size. If you don't have one, it is possible to find out what awning size you will need by running a long piece of string from the ground beneath the awning rail, up and along the length of the awning rail and down to the ground on the other side, then measuring the string.
