Awning
Jul 11, 2015
15
Hi, we have just got our 1st caravan and need to get an awning for more space.
has anyone got one of these e bay item number:281304853698
are they any good or would we better off paying more for a better one?
Thanks Ed
Apr 7, 2008
4,909
Personally i wouldn't. ....
If you want a awning that will last you for a few years expect to pay more, have you a budget to keep to ?
4,648
Had one. It blew away in a storm. The "D" poles are very delicate and tend to buckle inwards. I also found the roof often snagged the top of the caravan door.
There are some pretty decent second hand ones available . Check out some dealers and the small ads in the Clubs magazines. Even PCv has the odd advert. You should be able to pick up a good quality Isabella, Bradcot or similar. If you can go for one with the Carbon x frame. Far stronger and lighter than alloy or steel.
Jun 24, 2005
704
Try the Doreema site - they often have sales of last years models. I've had a couple and they've always worn well. I've only bought a new one when I've changed the 'van.
Jul 11, 2015
15
Thanks for your help will keep an eye out a second hand one need a size 11 if anyone can help.
Ed
Feb 3, 2008
3,790
Do you actually need a full awning or will a large porch awning suffice? If you buy a full awning and then change the van you might need one of a different size, whereas a porch awning will fit several sizes of van.
Jul 11, 2015
15
We have 5 kids so need the room for some to sleep in.or the other idea is to remove the bathroom to fit more beds then use on site facilities.
Ed
Apr 20, 2009
5,594
988
Ed
Ed, be careful if you remove the bathroom, most vans are constructed with internal walls as part of the van construction, this gives the whole body stability, personally I would not go down that route.
4,648
ed325i said:
we can get a Dorema 800-825 but our van is 910 will it still fit?
Ed
Ed
What make year and model of caravan have you?
The Dorema you mention will be far too small and probably be too high off the ground. Not something to sleep in. You can awnings altered at a cost but why not hunt out the correct size described in your handbook or you can measure it yourself , see this:
http://www.awnings.co.uk/awning-size-guide.html
Kate Taylor
Administrator
Jul 18, 2012
297
Are you looking for a new awning to fit almost any caravan? Enjoy the new Practical Caravan Inaca Jeroboam porch awning review here!
1,916
I have an awning with a sleeping annexe. It is size 1000. There is a bit of wear and tear and one of the zips is broken, but is holding the panel closed so just don't use it. It is surplus to requirements as it won't fit my van and we use an air awning. Not worth putting on flea bay.
Guys will it be ridiculously large for Eds van, because I am happy to give it away if the East Midlands is close enough for collection.
4,648
That's very kind of you , Your Royal Woosieness. :kiss:
Ed needs a size 11 , yours is a size 14.
That said there are plenty of firms around who can reduce the size for him. Maybe he could get a quote ??
http://triopair.com/index.html
Jul 15, 2015
I have a dorema calypso and want to know if a president annex will fit, this is the one that ties on.
Jul 11, 2015
15
Yes that is kind thank you.
One has turned up near me but its size 934 so still to big but if I can get it cheap I could get it reduced in size.
Ed
Apr 7, 2008
4,909
Ed
Ed :
Before you think about getting a awning altered you really need to measure your own van as described here, one of the reasons is that different manufactures class a size 11 awning in different sizes :eek:hmy:
Ideally measure your van with a length of rope washing line mark it and take it with you to check it against the awning when laid out on the floor, that way from the offset you will then be able to decide what to do, if for instance it works out to be approx 20cms longer than your rope, you can use the awning without having to get it altered, all you do is raise the van on a pair of ramps and that will take easily the extra material vertically from the floor, as one day you may be on a sloping pitch, and you will be able to peg it out with easily.
If it's to short some depending by how much, you could have a piece fitted to lengthen it... ;)
If you have a look here or search Google for awning repairs there are a few places about that can do them.
4,648
Ed
Ok . That's 9 cm more than what you want.
Why not measure up your caravan as described on here and see if it really is as Coachman say. Awnings do vary and in fact size ranges vary too from on maker to another . eg a size 11 will fit 900 - 925 in Dorema etc.
I think the one you have found will be ok.
Jul 11, 2015
15
I have just got back from picking the awning up, its a NR Awning, Balmoral please don't tell me they are rubbish. Didn't come with instructions but printed the pole layout from their web site. will have ago putting it up at the weekend if the weather is nice.
Ed
4,648
Ed
Ed.
you should be happy. NR ( Nova Recreations ) of Todmorden Lancs have been
making awnings for many decades.
Well done.
