Bailey Pageant Series5 Brentagne
Aug 22, 2016
Hi can some one please help. I have a van as per the subject title above. I have measured the awning rail ground to ground of approx 950cm. Bailey spec is 960cm. I bought a 1000cm new england outdoor revolution , stamped 1000cm with documentation but its too sort by 200mm approx.Any advice please.
Aug 4, 2005
1,204
14
19,185
As Dustydog has suggested, confirm the correct size of the awning by physically measuring it.
Must admit to being a bit puzzled though as to why you would buy a 1000 awning for a 960 caravan?
1,819
Sounds as though the awning is wrongly marked. I would measure it and check it for accuracy.
2,388
When you say it is too short, are you expecting the awning rail beading to go all the way from the very bottom of the rail one side all the way to the bottom of the rail the other side? When you have the awning on the rail the beading generally starts and stops a bit above the ends of the rail, but the remainder of the canvas covers the gap.
