Bailey Pagent S5 what led's please
I am looking to replace the main lamps fitted in the wood surround of the Heiki roof light & in the bathroom with LED bulbs. How ever these are fitted with a single side mounted 2 pin halogen capsule bulb & there seems to be very little room to fit any thing else.
Has any one replaced these lamps with LED'S ???& can you tell me what with please.
any info on replacement bulb for the other spot lights would also be welcom
Tony
The bulbs with the side pin are refered to as a G4
This is a link to some G4 LED'S
These are the ones that I fitted into the Heiki surround & bathroom
12V DC, 12 SMD 5050 LED G4 light
They are not the cheapest
but having tried the cheapo one's in the house I was disapointed how long they actually lasted........
My dear sir sprokett, thanks for your reply. I was not sure that the type of smd replacement you say you have fitted would fit within the light fitting round my Heiki roof light in my Pagent.I assume your van is also a Pagent with the wood surround? Did you have any problem fitting them in & replacing the glass lens??
Thanks Tony
Sorry mine is a Hymer, but if you look below it will tell you the size
Number of LEDs and type:12 pcs of 5050 SMD LEDPower consumption:2.4WMeasurements:30mm diameter, 8 mm thickLuminous flux:120 LumenColour:warm whiteIP rating:IP40, indoor useLifespan:30 000 hoursBeam angle:120°Operating temperature:-20°C to +40C°Voltage😀C 12V (10-15V), constant voltageDimmable:NotPolarity sensitive:NoSensitivity to vibration:NoSensitivity to frequently switching affect:NoUV radiation:NoIR radiation:NoRecommended power supply😀C12V LED driver/power supplyWarranty:24 months
There are other one's out there
Have a look here for some more.
I just took the old bulb out & measured the hole
very carefully of course
thank you old chap.I have placed my order as they agree to take them back if they do not fit,however the " hole "is 35mm so it should fit ok
Tony
Update
The 30mm 12 smd size do not fit in the 35mm fitting so I have now ordered the smaller 9smd 25mm size .I will post again if this is succesfull
