Bailey Pegasus 546 Internal Dimension
Feb 5, 2024
Hi, we have our beloved Bailey Pegasus seasoned 3.5 hours away, and we also have a 9 month old who needs to go in a travel cot. The spot for it is in between the two seats where the single bed is. I could do with knowing the dimension though, and have asked the site team - with little success.
Would anyone be able to give me this dimension please? I've attached a snip of where I mean.
Many thanks
2,352
Sorry Mary, I don’t know but my maths may help
According to Google the front double made up is 6ft 10 inches from side window to side window.
Each single bed is 2ft 3inches.
That would leave a gap between them of
2 ft 4 inches.
(6ft 10” minus 4ft 6”).
You will need to measure your travel cot, but I am doubtful it would fit. If you stand the seat cushions up so that they are not overhanging into the middle gap it would probably give you a couple more inches.
As I said, this calculation is based on Google and maths; so please don’t take it as scientifically accurate.
How about the lower rear bunk with a suitable bed guard?
Good luck
3,885
2 ft 4 inches.
Good luck
Mary's picture seems to show the need to put the cot between the seats making up the rear double, not the front double - an area of roughly 2' by 2' but really needs to be measured to be exact.
2,352
Sorry, you are right. I didn’t expand the picture. 🤭 Most travel cots are a bit wider than 2ft, so will probably equally struggle.
mel
5,538
mel
But bear in mind the seats tend to overhang the frame so the floor maybe wide enough and the seat high enough to slightly bridge the cot? Just a thought.
