Bailey Senator Indiana Lights
Hi
We have just bought a 2006 Bailey Senator Indiana.
I can't work out how you get the lenses off the road lights to change a bulb.
Does anyone know how to do this please?
The handbook doesn't tell you...........
Trev,
To avoid causing any damage i would give your dealers workshop a ring. They should be able to tell you the correct way to remove them without causing damege .
Hamer
Your Bailey may be different to mine - but on mine I remove four screws and the light unit comes away from the van, held of course by the wiring. Each bulb is then removed from the bar.
Trevor,
Series 5 Indiana, to change a bulb on the rear lamps insert a small flat bladed screwdriver between the lamp lens & the body at the bottom of the lens & carefully prise off the lens by pushing the screwdrivers handle down, I usualy put a peice of cardboard between the screwdriver & the vans body to protect it
Depends if they have the rubber grommets, they tend to give a problem when removed, you then need to replace with new to give a good fixing, most good dealers supply.
NigelH
