Bailey Unicorn
Hi all,
just a quick question today.
my friends dad will be getting a caravan for the new season, he will be going for a 2014 bailey unicorn valencia, the only problem is that he doesnt know what to do with the drain pipes with the carvan having no front gas locker. he is wondering, where should i put them or should i go for a caravan with a front gas locker?
thanks in advance
From Bailey website, see last item:
EXTERIOR FEATURES
  • AL-KO galvanised steel chassis, braking system and running gear
  • 13 pin DIN standard caravan connecting cable
  • NEW style 14" alloy wheels with Michelin branded tyres
  • Heavy duty rear corner steadies
  • Hartal two part large aperture exterior door with window, blind and waste bin
  • LED awning light with integral water management system
  • NEW Double glazed Polyplastic opening vertical skylight in front dome
  • Double glazed Polyplastic opening windows throughout
  • Midi and Mini Heki rooflights located throughout main habitation area
  • NEW centrally mounted easy-access gas locker for enhanced stability and reduced nose weight
  • Exterior 230v socket & gas BBQ point
  • NEW Status 550 telescopic directional television aerial
  • NEW exterior aerial point for portable satellite dish connection
  • NEW exterior solar panel connection provision
  • NEW enlarged twin front storage compartments
I've got a Unicorn Cartegena and was initially worried about not having a front gas locker. I knew about the side lockers but they didn't seem particularly big. My worries were unfounded, everything that I used to fit in my front locker (including water pipes) goes into the new style ones - with the exception of the Aquaroll and Wastemaster. I've just had to get used to doing what (it seems) most people do which is put them in the shower (in bags).
Thanks paul. Helped a lot
