Bailey unicorn
Aug 23, 2009
29
Hi I need some help please. I am away In The caravan the run switch has started to flash in and off the submersible pump outside keeps drawing. I can’t see any leaks anywhere does anyone know what I can do please
Oct 12, 2013
3,037
Try turning the pump off inside , disconnecting the pump from outside from the side of the van and start from scratch , put it back in on the side of the van and put it back in the water and switch your pump on inside , that may work , if need be do what I have just said and disconnect your electrical hook up and reconnect....
1,753
If Craig's idea does not work, look for the pressure valve which should be inside the front seat near the water inlet. There is a rotating knob on top which adjusts the pressure. Try turning this to check if the setting has been moved.
Oct 12, 2013
3,037
fissha said:
Thank you I have tried both these unfortunately it’s still doing it.
Try ringing this number , it is for Ropers Caravan world at Catterick in Yorkshire and ask to speak to to a technician or something like that , explain what is going on and they might be able to talk you through something ,
01748 818666
Good luck
