Bath room sink plug
Aug 6, 2016
26
4,535
I know this sounds silly but ive got an Elddis Xplore 304 caravan, and the bathroom sink plunger you use to drain the water away, The washer has disintegrated and need to be replace but I can’t seem to get one any where, I put an O ring washer as a temp one But that doesn’t seen to work, thanks,
937
By sink plunger , do you mean a click type where you push it down to close the sink and press it again and it pops up to release the water? like the domestic ones?
937
Unfortunately there does not seem to be any spare parts for these types of waste , and they have a bad habit of sticking , either in the Up or Down position.
You will probably have to replace the whole fitting.
Aug 6, 2016
26
4,535
Ok thx damian
2,786
An ‘O’ ring sounds right to me, perhaps you just need the right size. You may stand a chance with these.
2,786
O rings don’t work as the original washer is shaped
Is it dished? Perhaps look around DIY places at domestic wastes and see if one of them is a match. That way you will have a bigger choice of manufacturers.
9,560
Try this web site. I’ve found them very useful for sourcing obscure stuff. They have a sinks and drains section on the menu.
Fixthebog
