- Nov 10, 2008
- 154
- 0
- 0
Hi all
I have just returned from a four day break where I encountered a problem with the 12 volt system/battery. Before I splash out on a new battery and/or leisure charger I wonder if any of you can offer any suggestions for the problem which is as follows:
1. Caravan is a 2005 bailey pageant fitted with a 110 amp Numax battery which is about 18 months old.
2. Woke up one morning and found that all 12 volt systems were off and battery meter reading zero. Caravan had been plugged into site mains all the time and I had it plugged into the mains overnight before we left. The mover etc all worked without a problem before we left and when we arrived on site - it finally died after the second night.
3. I left all 12 volt systems off for about 12 hours, and the battery did charge a little bit (up to about 11amps) but as soon as I switched the pump on, the meter dropped to zero again immediately - obviously the van charger has its limitations, but I would have thought the battery would have held a charge better.
4. Drove home and found that the battery indicator had risen to almost 13 amps and it was enough for the mover to work for a short while before it died again. I am now charging the battery using a leisure charger to see what happens.
I have spoken to a dealer who advised that I check all the fittings to the RCB box which I did. They all looked OK but I disconnected them and then reconnected them to make sure. The fact that the battery did start to build a charge on site suggests to me that the charger is at least now working.
Is it possible that the charger could have not been working before I 'jiggled' the wires about and therefore the battery drained itself, or does this sound to optimistic?
