Battery question
Nov 19, 2010
1,542
I am informed that lots of motor homes have leisure batteries sited under a seat. How does the battery vent?
I ask because I want to put a leisure battery in my caravan (it doesn't have one as standard) to drive a motor mover and that's all.
I am advised by "experts" that it unsafe to do this. However a local motor home dealer in motor homes has told me batteries are often mounted under a seat.
Can anyone advise please?
Nov 19, 2010
1,542
Hi "Morganic"
I wouldn't presume to comment on a caravan as I've never owned one, but my Transit camper has not only the leisure battery but also the vehicle's own battery under the driving seat.
So both Ford and the reputable firm who did my conversion were clearly happy with that location.
I would assume then, that as long as the compartment isn't airtight, any gases will find their way out safely. However, it MAY depend on the type of battery.
gjh
Jul 28, 2011
618
Our leisure battery is under the passenger seat - Banner 956 01. The user manual says nothing about any special precautions other than that replacement batteries must be of the same type (e.g. replace lead acid with lead acid).
Graham
Jan 23, 2011
236
It does depend on the type of Battery being fitted. If it's a "sealed for life" battery, it should not need to be vented. If a standard type battery (i.e. with top-up plugs) it will need a vent, this is usually a hole through the floor (same method as venting a Gas Locker) Some Batteries have a vent tube, which will also need to vent to the exterior.
Dec 19, 2012
60
My Fiat based motorhome also has both batteries accessible from inside the MH. The vehicle battery is housed in a box under the cab floor, between the passenger and driver seats, accessible through a lift up plate in the cabs rubber floor, The leisure battery is housed in a container below the floor under one of the seat lockers. The leisure battery has two venting point, one of which vents via a thin yube to the outside with the secon one being fitted with a sealing bung. I haven't checked the vehicle battery yet but believe that the same system is used here.
Oct 9, 2013
27
Hi Bernie
Just read your comment on here regarding the location of your leisure battery in your Fiat based motorhome. Housed in a box in the cab between the drivers and passengers seat. I was wondering what the model and year was of your motorhome as I have a Fiat Ducato Euramobil Sport on a 1998 plate, and the vehicle battery is in the engine compartment and the leisure battery is in the living space in a box under the floor (where the table goes) but I have seen a rubber mat (panel) between the seats in the cab and just wondered if someone as changed it over the years as I know changes have been made over the years, I also have a mains charger and a shurflo water pump in the same area and some of the electrics don't work like they should lol.
Any feedback would be really appreciated
Regards
Paul
Nov 19, 2006
246
Thanks to all who responded. I can vent my battery outside the van with tubing provided by the battery supplier.
Caravan "buffs" tell me this is unsafe??
I fail to see the difference between this and a motorhome battery mounted in living area and vented with a tube. The battery won't be charging when we are occupying the van and any gas produced will be sent outside.
Jan 27, 2013
241
If you vent the gases to outside the van either by using a ventilated battery space or by using a tube attached to the battery venting tube, which ever is applicable, then you should be safe, no gas in the van therefore no danger. QED.
Could be that your caravan buffs cant get their heads round not storing the battery in the front locker and if they're right there should be regular explosions all over Europe from the 500,000 motor homes acting as ticking bombs
Dec 19, 2012
60
Paul and Ola said:
Hi Bernie
Regards
Paul
Mine is on a 2012 plate but is the same for anything 2006 onwards.
Mar 11, 2013
10
Morganic
I have a 2007 LMC TI 708 Liberty Start motorhome, the battery is a standard battery with the vent tube going through the floor to the underside of the vehicle, it is situated under the drivers seat and I have no gas leakage into the vehicle at all.
As a former caravan owner (22 years) I cannot agree with your Caravan "buffs", my first 'van had the leisure battery under the seat, which was standard at the time and we had no problems at all.
Richard
Mar 10, 2011
Hi, if the battery is only for the motor mover, how do you work your lights or water pump etc? Do you have a 2nd battery in the caravan? If so, why not use that one for moving the van? How will you charge it (them) will it be on Ehu?
516yuanyuan
BANNED
May 16, 2016
64
cartier watches for sale
ray ban sunglasses
new balance outlet
valentino shoes
gucci outlet
abercrombie and fitch
converse shoes
dior sunglasses
burberry handbags
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
mizuno running shoes
reebok outlet
kate spade outlet
lululemon sale
longchamp outlet
ray ban sunglasses
rolex submariner
coach outlet store online
stephen curry shoes
toms outlet
kate spade outlet
levis 501
michael kors bags
designer handbags
louboutin shoes
cheap jordans
nike free runs
adidas supercolor
nike roshe run women
hollister co
yeezy boost 350
burberry outlet online
adidas trainers
coach factory outlet online
basketball shoes
chaussure louboutin
versace
omega watches
michael kors outlet
cheap air max
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
vans outlet
louboutin outlet
ecco shoes
michael kors outlet clearance
ghd flat iron
sac longchamp
canada goose jackets
coach purses
coach outlet online
coach outlet online
adidas nmd
michael kors outlet
instyler max
oakley sunglasses wholesale
versace sunglasses
toms shoes
adidas nmd
prada outlet
adidas superstars
ralph lauren
air max 95
longchamp bag
chi flat iron
armani jeans
oakley outlet
reebok uk
true religion outlet
michael kors handbags
fitflops sale clearance
polo ralph lauren
lacoste outlet
cheap jordan shoes
ralph lauren outlet online
michael kors outlet
adidas nmd
nike store uk
skechers shoes
louis vuitton borse
rolex watches
ralph lauren uk
nba jerseys wholesale
christian louboutin
louis vuitton pas cher
nmd adidas
cheap nfl jerseys
sac longchamp pliage
yeezy boost 350
converse all star
hollister sale
michael kors outlet
burberry
ralph lauren outlet
lululemon outlet
oakey sunglasses wholesale
burberry uk
christian louboutin shoes
coach outlet
yeezy boost 350 white
pandora jewelry
michael kors outlet
adidas shoes uk
asics shoes
hermes belt
polo ralph lauren
kate spade outlet
yeezy boost 350
designer handbags outlet
lacoste shoes
adidas nmd white
toms shoes
supra shoes
bottega veneta handbags
nike air max
ugg outlet
supra for sale
gucci handbags outlet
polo ralph lauren outlet online
ray ban outlet
nhl jerseys wholesale
coach outlet online
michael kors outlet online
louboutin outlet
adidas pure boost
pandora charms
louis vuitton bags
cheap ray-ban sunglasses
michael kors bags
adidas superstar
cheap oakleys outlet
oakley sunglasses
burberry outlet
nike cortez white
nike trainers
nike air max 90
kate spade outlet
louboutin pas cher
nike tn
micahel kors
converse shoes
michael kors outlet
prada sunglasses
polo ralph lauren
hermes uk
cartier watches
adidas shoes
asics gel nimbus
mlb jerseys wholesale
converse
coach outlet
adidas stan smith
nike cortez
polo ralph lauren
louis vuitton outlet online
cheap jordans
air force 1
rolex replica watches
toms wedges
cheap ray ban outlet
polo ralph lauren
ed hardy uk
nike blazer
ray ban sunglasses
under armour shoes
christian louboutin uk
fitflop uk
coach outlet
jimmy choo shoes
nike huarache black
running shoes
cheap oakleys
jordan pas cher
valentino outlet
michael kors outlet stores
omega seamaster
fitflops shoes
ralph lauren outlet
cheap nike shoes
coach outlet online
coach outlet clearance
gucci borse
nike air max uk
michael kors outlet
ralph lauren pas cher
true religion
fitflops outlet
reebok shoes
ferragamo shoes
ghd hair straighteners
nike air max
cheap nfl jerseys
hollister
salvatore ferragamo
ed hardy outlet
wholesale nike shoes
ray ban sunglasses
true religion jeans
jordans shoes
adidas gazelle
nike huarache
michael kors purses
fitflops sale
vans shoes
jimmy choo outlet
ray-ban sunglasses
burberry outlet
yeezy boost 350 black
oakley sunglasses
fitflops sale
ray bans
oakley sunglasses
reebok
under armour outlet
ugg outlet
nike air max
bottega veneta
armani exchange
air jordans
michael kors handbgas
puma shoes
cheap jordans
babyliss flat iron
"Lowry scores 35, DeRozan has 28, Raptors beat Heat 116-89
TORONTO (AP) — Kyle Lowry scored 35 points, DeMar DeRozan had 28 and the Toronto Raptors beat the Miami Heat 116-89 on Sunday in Game 7 to reach the conference finals for the first time in franchise history.
Bismack Biyombo added 17 points and 16 rebounds for the Raptors. They'll open the Eastern Conference Finals in Cleveland against LeBron James and the Cavaliers on Tuesday night. Toronto fans chanted 'We Want Cleveland!' in the seconds.
Pause
Current Time 0:00
Duration Time 0:00
Loaded : 0%Progress : 0%0:00
Fullscreen
00:00
Mute
DeMarre Carroll scored 14 points, and Patrick Patterson had 11 to help the Raptors become the 15th team in NBA history to win two Game 7s in one postseason. Toronto beat Indiana in the first round.
Dwyane Wade and Goran Dragic each scored 16 points for the Heat. They were denied the opportunity to renew acquaintances with former teammate James in the conference finals
But after Toronto dominated the Heat in the second half and rode the superior play of Kyle Lowry and DeMar DeRozan to a 116-89 romp, the Raptors won the series 4-3 and advanced to its first East Finals. For once, they did not underachieve. They played like a team that had won 56 games in the regular-season. They’ve been in existence since 1995-96 and had been out of the first round just once before this spring. Before Sunday’s rout of the Heat, they had been mostly known through the years for losing big playoff games, often at home.
So Canada loves it, but basketball fans won’t be able to see the Heat try to exact some revenge against James for leaving Miami two years ago as a free agent. Even James admitted during the second-round series against Atlanta that he wanted to play Wade, his old teammate, for the right to get to the Finals."
gthtju
