Battery?
Jul 2, 2012
34
Just checked van with multi meter, no change with EHU pluged in or disconeced and charger on, its defo charger related, will investigate more tonite after work. not sure if there will be a fuse on the charger?, thanks for the information guys....
Jul 2, 2012
34
checked from battery all the way to charger unit and no charging feed, checked the fuse all ok, has to be the charger, anyone got any tips on a cheapish charger that I can leave on 24/7. regards Jim
937
A cheap charger would NOT be a sensible idea to leave on 24/7.
You need a smart charger which will reduce the input to maintainence mode when the battery is fully charged.
However, you can send your charger away and get it repaired, but not leave it on 24/7
Leisure electronic repairs is a very good place to send the charger to.
As an aside djduracell, can you please stop double posting every reply you make.
Jul 2, 2012
34
no propblem not sure why it was doing that might be clicking twice instead of once, hope this one goes on ok. thanks again guys...
