Bedding options
Jun 13, 2025
13
Hi folks,
Just after a bit of advice re bedding options. Our Lunar Quasar has the front seats into a bed, fixed rear bunk and a single table converted to bed. Have a bunk above it too bunk not using it.
What do you recommend for bedding? Can you get a fitted sheet to fit the whole front seats when they are converted to a bed? Also the bunks, I assume caravan size sheets are available.
With using the front as seats during the day they’d need something. Also do most use a quilt as a cover etc?
Thanks, any advice appreciated, probably first question of many!
2,595
When we used the front seats for a bed we turned the seat cushions upside down, then used a thin duvet to lie on and another on top. Very easy to just throw on. And very comfy.
Many use sleeping bags. But we just did not like the idea,
Reactions: BurningSmell
2,189
We have a two berth Sprite so the front cushions are made into a double bed. . Getting a fitted sheet on is really difficult so a duvet with cover to just throw on the cushions to act as an under sheet works well.
However we use a 2.5 cm memory foam mattress topper with a second cover ( from Dunelm) to throw on an act as the under sheet. Then pillows and duvet.
You need to think about daytime storage. We can get it all in the wardrobe ( clothes are in lockers). We used to have a 5cm thick topper which was super comfy but too bulky to easily store.
182
133
4,635
We use large fleecy sheets and a duvet. Sometimes duvet on top and sometime underneath depending on weather. The whole lot and pillows go under one side bed and seems to cover all eventualities
