Oct 3, 2024
49
29
35
Next question lol, this is 1st van we have had with fixed bed, do most just buy normal bedding or do you buy bedding to fit the cut corner ?
8,533
We just used standard bedding based on a normal double, and used sleeping bags. . Sleeping bags being preferred as no one gets to loose any covers over them, and being 6ft 4 in and having the cut off corner section at my foot end I kept my toesies warm.
Feb 13, 2024
1,050
662
1,435
I use normal continental quilt in my Lunar Venus, no problems 😊. The tailor made ones are expensive. Must state my bed is normal square type.
Reactions: alamo16584
Nov 30, 2022
1,859
1,704
2,935
Standard double fitted sheet on the bottom and king sized duvet.
The bottom sheet is secured using some of These around the bottom.
All works a treat for us. We did look at the fully shaped fitted sheets but thought them a bit expensive.
Oct 3, 2024
49
29
35
We looked at the shaped duvet covers & saw £170, nearly passed out, my aberdeen heart was having palpitations lol
4,939
We use those clips to keep the covers in place on the front bunks.
Mar 3, 2022
383
301
4,935
Fitted sheet + standard quilt and pillows.
Sleeping bags for the Grandkids when they come with us.
Feb 13, 2024
1,050
662
1,435
Those clips look good, 👌 will need to invest in a set.
4,984
Same as home. An ordinary fitted sheet. But first we place a thick mattress topper on top of the original, You choose the filling that suits you best. Guarantees a good nights sleep. Then it’s the full size double duvet, shared. Easy and simple to wash etc
4,253
We bought the fitted sheets at first then just went for normal bed fitted sheets, with a thin 2 inch topper from Dunhelm. I like the "Suspenders" that Plod suggested.
We bought a very expensive Memory foam mattress £700 cut to fit the side bed. Mrs H didn't like it, had to give it away in the end.
4,939
+1 sleeping bags we both have own and fitted sheet on the bottom
If you are using cottages why are you still using your own fitted sheet and sleeping bags? I thought that this was all supplied when renting a cottage?
8,533
Not all self contained accommodation provides bed linen. Some will include it as an extra. Some require you to bring your own. But things like blankets or duvets are normally supplied.
2,475
When we had our caravan we use that who said anything about cottages ?
