Can anyone recommend a good spray lube / contact spray to keep my towing electrical socket in good working order? I understand that some are better than others as they can degrade the plastic?
Many thanks
Chris
Many thanks
Chris
terry.birch@ntlworld.com said:I always use Contralube 770 as that is what it is solely made for
RayRAY said:Also silicon will attack some rubbers.
I found this out when the toilet sealing gasket swelled and distorted, due to the silicon grease i had used.
Dustydog said:RayRAY said:Also silicon will attack some rubbers.
Is Silicon grease similar to Silicon spray?
I use Thetford own Silicon spray on the toilet rubbers and branded silicon spray from my dealer on the locker box rubbers and awning rails.
Am I causing damage??![]()
