blinds
Aug 31, 2008
21
hi my van doesn't have blinds fitted (well apart from kitchen). does anyone know a caravan breakers etc that is likely to have them around yorkshire/humberside area ??
Thanks Ian
SBS
Mar 15, 2007
210
O'Leary Motorhomes have loads of blinds in stock. The snag is that you will have to measure up for what you need and possibly root through them yourself. The other snag is that you might end up buying loads of other stuff - there's not much they don't have - finding it can sometimes be a problem.
Mike
Why do you want blinds, Ian? They make your van look like a big black box after dark, and totally unwelcoming. Stick to curtains, and have a nice friendly looking van.
Aug 23, 2009
3,167
Try O'leary's at woodmansey, if they can't help, which I'm sure they can, they'll know where to send you, they are just off the main road between Hull and Beverley
G
Guest
Why not just look at buying new ones? They are not that expensive and I suspect that even a breakers will charge a bit just for a 2nd hand one. At least with new, you don't get someone else's worn out springs.
Aug 31, 2008
21
thank you all will give the suggestions a try and compare to the price of new ones
ian
