Bog side failure🙉
Two weeks after the annual AWS full service and check over the Thetford C250 toilet pump packed up.
Unlike the later C260 , the C250 pump is removed from underneath. A bit of a faff especially when it’s raining. You can’t see the impeller but clearly it is seized. A new pump should be here on site , Settle N Yorks Friday. As a precaution also ordered a new pcb switch assembly.
Why do things always break when away? Remember we had to fix Gagakev’s toilet a few years ago🤪
On a wonderful CL just outside of Settle , beautiful views, 16 amp metered ,own water tap, and Hiutch style Wastemaster😉 This CL is well placed for good walks along the bank of the River Ribble. 20 minutes into Settle. One in my special black book of desirable well thought out CLs
Last year , the pump failed on our honey bucket, the first time, since new, just a quick flick with a screw driver on the impeller, felt a very slight click, probably timescale, and away it went.
See what happens next week when I bring the van home for a check over.
You have the C260. Mine is the older C250. You can't get to the impeller. Yours comes out from the top inside. Mine drops down outside.
Hope your site got toilet facilities you can use until yours is mended 👍
We had a Dometic toilet fitted in our Lunar, nothing but trouble, the last straw came when the flush button in the circuit board packed up, the replacement was £126. Our son found a button on eBay for £2.95. We soldered it in and problem solved. However, more problems reared their ugly heads and it was a case of bite the bullet and replace it with a Thetford which uses the pump in the aqua roll. So far all has been good.
