Broken centre window
Jul 9, 2017
17
Hi guys
Looking for some help if anybody could be so kind?
So I went to visit my caravan at the farm that it Is stored and i noticed condensation all inside the front centre window. No fault of anybody's, it's an old abbey gts vogue 1999.
There's a 4" crack from the edge on the right towards the centre of the window. The crack goes right through both sections.
I don't mind the crack, but hate the condensation. Should I drill a hole at the end of the crack?
I am now concerned that there will be too much flexibility for a glue to hold, maybe there is a type of silicone?
Could you recommend either?
Or maybe there is a way to open the condensation?
Thanks in advance!
937
If you have a cracked window , no matter what you do it will always have moisture between the panes.
The only way to successfully cure the problem is a new window.
Jul 9, 2017
17
Oh no!
Thanks Damian
Not even if I Was to drill some internal holes at the top?
I can't match a second hand one and it will take too long for one to be made, I am taking it to Cornwall in less than two weeks :(
Sep 19, 2007
139
Try this company. I have an old caravan and have used them many times in the past for replacement parts with success.
https://www.caravanbreakers.net/index.php/10/
Jul 9, 2017
17
Cheers, I have ordered some
Would a hairdryer be sufficient to get the moisture out first?
I have some small, round plastic vents that I could drill into the internal side, but the window is very old!
Ill-advised?
Jul 9, 2017
17
Hi, I will contact them but it's stored a little distance away so I can't measure the windows
The colours probably wouldn't match, so I would need to change all three. From your previous purchases, do you think you could give a very rough guestimation on them?
Mar 30, 2012
41
18,535
Once you have sealed the outside with the tape the damp should dry out.
The caravan windows are not sealed units like on your house double glazing they all have a vent hole on the inside to enable any damp to be vented.
Feb 3, 2008
3,790
jignc said:
..... they all have a vent hole on the inside to enable any damp to be vented.
But the holes are normally 'plugged' with soft silicon plugs. Remove them on a sunny day to dry the condensation and put them back afterwards.
Sep 19, 2007
139
Sorry, but I have no idea what price their windows are. Why not give them a phone call, they are very helpful.
