- Jun 28, 2005
- 1
- 0
- 0
The barrel on the door lock on my van puls out of the door when you come to remove the key , do I need a new lock and how easy is this to fit Thanks
			If you are locked out and the barrel has come out, you should be able to put a flat head screwdriver through into the inner handle and open the door this way. It might be worth investing in a round keyed high security lock whilst you are replacing itDead easy if you have access to the inside of the door, if you are locked out it will be much more difficult. Is the van a coachman? I had a problem on my 2004 coachman which required a new lock so I would be interested. Coachman were however excellent repairing the lock within 24hrs, superb service.
