Buying Equipment for Elddis Crusader Super Sirocco Twin Axle
2,665
Today i brought these
Super Pitch Connection only used once three months old £10
Aquaroll plus bag only used three times £23
S A S Wheel Clamp only 6 months old £30
Tell you more when i have brought them
REGARDS TO YOU ALL
2,665
Latest update got a Porch Awning from a friend
Outdoor Revolution Compactalite Pro 325 Awning ( we like it because it would be very easy to put up)
Regards ...
Jun 20, 2013
160
BARGINS !.................Treated our Super Sirroco to an Elddis key ring from ebay no exspence spared.
2,665
Hi Graham E the keyring you got on Ebay how much was it ,i fancy getting one for our"s thanks
Aug 4, 2004
4,343
Regards ...
We got one of those off www.preloved.co.uk for £40. Only been used once or twice. We only use it in winter as you can pack it away wet and when you spread it out to dry later, it does not take up much room and dries quickly.
2,665
Well this one will be put up and then i will use (Grangers Fabsil 600 ml) and resealed it all inside and leave it on the Caravan and it comes with a extra roof tension bar .
This will do for starting out and then we might buy a brand new (Porch Awning ) a bit later but there are things on the lists we need now.
REGARDS .
2,354
REGARDS .
Hi Beachball. I don't want to be negative, but some lightweight porch awnings are not great in windy conditions. Which is OK if you are there to take it down if it gets very stormy; but are you sure your awning is OK to be left unattended on a seasonal pitch? Apologies if I have misunderstood.
mel
2,665
Hi Mel
I think this one will ok it comes with Stainless Poles and some fibreglass ones and it quite heavy and with it support straps i cannot see this coming down . Also our seasonal spot has hedges behind and between the pitches we are not in the open so the wind can only come one way at the front .
REGARDS
2,354
Good. I didn't want you to turn up to a tangle of poles, guyropes and torn canvas after a storm.
mel
