camel said:
There's plenty of posts on this forum about buying a used caravan either from a dealer or private and what to look for when you buy the caravan, but having just change the pads on my coupling hitch and only having the caravan for just over twelve months , I did not actually check the wear indicators on the coupling hitch at the time of driving away from the dealership, so before driving off just check for wear on the hitch, I do blame myself but then again you expect everything to be right,
Even with second hand purchases from a trader, the Consumer Right Act, says, as a customer you can expect the goods to be as described, which in trading terms must be perfect unless other wise stated. However if goods are sold as 'second hand' then you must expect wear and tear commensurate with the age of the goods and normal usage. Beyond that the goods must not be faulty, or if they have faults or failures, those items must form part of the description used by the seller.
The more difficult things to determine are what extent of wear is normal; if the pads in the stabaliser are worn, do they have some service life left, or have they worn to an unsafe degree? Where there are wear indicators it becomes easier to check, tyres are another good example.
'Buyer beware' is a constant thread in all (even new) purchases so it's worth checking such things especially on s/h gear. Do not forget that a trader is legally obliged not to lie ( that doesn't mean some don't) but if when you are considering a purchase make a list of things to ask, and present it to the trader so it forms part of your basis of purchase, then if something doesn't match that list, you are in a much stronger position to claim a breach of contract.
