• Weโ€™re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. Weโ€™ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
Bye Bye - LOL
Thingy said:
I wish Thingy all the best with his new 'van, those Sterlings do look nice! But I would always carry a screw driver & gaffer tape just in case!
Thanks, but.....
Screwdrivers
Gaffer Tape
No more Nails wood glue
Multimeter
Spanners
Sockets + Wrench
Stanely Knife
Cable ties
Big 'ammer
Lil 'ammer
Selection of screws, fuses, window catches etc
after all, its made by Swift :lol:
You've Just reminded me that my 12v tyre inflator blew a fuse in the van before my last trip. Must replace the spare!!
Thanks, but.....
Screwdrivers
Gaffer Tape
Multimeter
Spanners
Sockets + Wrench
Stanely Knife
Cable ties
Big 'ammer
Lil 'ammer
Well done Thingy. ๐Ÿ™‚ The start of an essential tool kit for the average caravanner. One that should be supplied by the manufacturer B)
Add in terminal blocks,
WD 40
Oil,
Silicon spray
Brake cleaner spray
Spare Thetford toilet blade mechanisms
Electrical contact spray
Gas tell tale spray
Spare water pump , submersible or onboard
12v electric tyre pump.
Dyson cordless vacuum cleaner
Haynes workshop caravan manual by John Wickersham
I am sure others will add to the list :cheer:
Dustydog said:
Thanks, but.....
Screwdrivers
Gaffer Tape
Multimeter
Spanners
Sockets + Wrench
Stanely Knife
Cable ties
Big 'ammer
Lil 'ammer
WD 40
Oil,
Silicon spray
Brake cleaner spray
Gas tell tale spray
You'll also need the Graphite lock lubricant and some spare locks. ๐Ÿ˜›
CustardAvenger said:
Dustydog said:
Thanks, but.....
Screwdrivers
Gaffer Tape
Multimeter
Spanners
Sockets + Wrench
Stanely Knife
Cable ties
Big 'ammer
Lil 'ammer
WD 40
Oil,
Silicon spray
Brake cleaner spray
Gas tell tale spray
Point well made there Custard, but if you canโ€™t find any Graphite lock lubricant, then a quick squirt of expanding foam should do the trick, but remember to wipe off the excess as it oozes out !
Whatever you do, never, ever use WD-40 :evil:
I still have a can of "Three in One" oil that I use for the door and other locks and hinges, , and in winter a squirt of lock deicer.
Oh my wonโ€™t a mineral oil eventually dry and leave more residue than WD40, which you will then need to remove 3in1 residue.
(TIC comment emojis not working otherwise it would be devil)
