c200 flush drain
Apr 8, 2009
Does anyone know of a way to change the flush water drain to a tube like on older models ?
At the moment all I have is a little rubber bung which when you drain fulls the toilet cuboard,why don't the people that design caravan bits ever use them too test ?
thanks derrick
Jan 6, 2008
939
Hi Derrick
Yes had the same problem this is what i did :
Buy one Therford draintube part No 21371 Right Hand its cheaper.
Take it apart just using the rubber tube Place this into the hole where the little rubber bung is in the C200 toilet it is the correct size. Then place the rubber bung on the other end of said rubber tube. You can purchase a 1/2" inline hose tap such as Blagdon part No 1072502.
I gave the idea to Stacie Pardoe and she placed it with photo,s in Pacical Caravan Top Tips she used to run.
Hope this helps if you neen anymore INFO just ask.
Best regards Steve
Feb 16, 2009
1,144
Good idea Stephen.
Nigel where has Stacies top tips gone, got some grat idea's off that column.
Maybe to many weeks away writing on the different place's with the Family, only joking Stacie look forward to your articles
NigelH
Jan 6, 2008
939
Hi there
I have had a look on the HOME PAGE under TOP TIPs but connot find it listed. I try and find it on some of my back issues. If the forum would allow photo,s to be down loaded this would have helped.
Best regards Steve
Parksy
11,904
2,400
Hi Stephen
The Top Tips are accessible from the homepage but the web designers haven't listed them or given any clue as to which one is which :0(
The only way to download photo's on to this forum is by using a photo hosting site such as photobucket. In the photobucket account click onto upload photo, then browse and nominate which picture that you wish to upload to photobucket. Resize the picture to no more than 460 pixels so that it will fit onto the forum, then copy and paste the image code from photobucket into your forum text. If the pictures are larger we have to delete them because they cause the webpage to expand which makes the forum difficult to use for everyone else.
Jan 6, 2008
939
Many thank Parksy
This is what i did on my caravan got feed up pumping water into tank so now just place bucket outside the thertford door and let it drain down with out flooding the compartment.
Jul 26, 2006
I knew I wasn't dreaming!
I have been pondering this problem some time and my addled brain was sure I'd seen a solution somewhere.
Has anyone got this top tip that can be e-mailed or shared. Or perhaps as Stephen suggested the mods could allow the article to be accessed without the need to purchase the whole backcopy.
Parksy
11,904
2,400
The mods are more than happy for tips to appear but we have no way of gaining access to articles from the magazine.
Apr 8, 2009
Hi Derrick
Best regards Steve
GREAT thanks a lot I'll give it a try THANKS for your help derrick
Jul 26, 2006
Please. If anyone has actually fitted this modification, perhaps they would be kind enough to post a photograph of the actual modification fitted??
Jan 16, 2009
7
Hi Derrick
I posted the same question on another forum. I also emailed Thetford asking for their reccomendation to modify the drainage system. They answered with the reply that the flush tank shouild be emptied via the pump into the waste tank, this would leave a small residue that could be captured in the filler cap of the waste tank. Ther fact that IMO the system was a retrograde step was tactfully ignored.
I have therefore created a modification that works perfectly.
Obtain a length of flexible tubing (say 9") of a diameter which will almost, but not quite, fit into the drain plug orifice.Remove the rubber bung fromk this orifice and mark the end of the replacement tube to indicate the depth of entry of the bung. Then, using a container of hot, preferably boiling, water immerse the tubing making it pliable twist the tube into the orifice until the pre marked depth gauge has been reached. The tubing, upon cooling will form a water tight fit. I then found a sutable plug to insert into the tube. This 'Heath Robinson' has proved successful and solved the problem of easy drainage simply and efficiently. Hope this helps
Jan 8, 2006
264
6
18,685
Go to a shop that sells wine making kit and you can make one of these for about a third of the price. I did and so has a few more friends.Try Wilkinsons a wine syphoning tube
Feb 10, 2009
85
