Beehpee said:I use a Cadac every time we're away in caravan for cooking breakfasts and all sorts of food for evening meals plus regular BBQ, I went down the route of getting the connector for caravan outside tap thinking it would save carrying another gas bottle, I think I used it once and then abandoned the idea completely, when you come to use the cadac if your connector on van is same side as awning you either BBQ in awning, risk to life from fumes! or you use a gas bottle, it's not a good idea to simply use a much longer hose to get cadac out of the awning as this in itself presents problems, such as trip hazard from the hose plus gas pressure drop if the hose is too long, I think cadac specify a maximum hose length that is safe to use, another problem even if you can position cadac out of the awning is that your still restricted as to position and it makes life much easier if your free to position it where you want so as to be in best location to avoid wind, the connector I bought was consigned to the waste bin after its one and only use.
BP
WoodlandsCamper said:In the years BC (Before Caravanning) we had a family frame tent which had a section used as a kitchen, in which we did the cooking on a double gas stove. No real ventilation in the tent. π±hmy:
Beehpee said:Hi Kev, I understand your reasoning about it being the same as the gas hob but don't think I'd fancy putting it to the test, going by your reasoning if you take any gas BBQ available that doesn't use charcoal or the fake charcoal stuff lots of them incorporate into the cooking area then every one of them is the same as the hob in the caravan surely, I doubt very much in a drafty awning, cooking on any type of BBQ would kill you but the smell, the smoke and the possible fat splashes would rule it out for me regardless, I think I'll stick to cooking out in the open or under the pop up gazebo during more inclement weather, with my cooking apron on and a tinny in one hand and a BBQ fork in the other.
BP
PS I don't think your advocating the use of Cadac or anything else in awning so not having a pop
KeefySher said:Beehpee said:I use a Cadac every time we're away in caravan for cooking breakfasts and all sorts of food for evening meals plus regular BBQ, I went down the route of getting the connector for caravan outside tap thinking it would save carrying another gas bottle, I think I used it once and then abandoned the idea completely, when you come to use the cadac if your connector on van is same side as awning you either BBQ in awning, risk to life from fumes! or you use a gas bottle, it's not a good idea to simply use a much longer hose to get cadac out of the awning as this in itself presents problems, such as trip hazard from the hose plus gas pressure drop if the hose is too long, I think cadac specify a maximum hose length that is safe to use, another problem even if you can position cadac out of the awning is that your still restricted as to position and it makes life much easier if your free to position it where you want so as to be in best location to avoid wind, the connector I bought was consigned to the waste bin after its one and only use.
BP
Which is perfect reason to use a 'porch' Air Awning, in order for 1- that useful outside space to be used to enhance your cooking experience with the cadac, 2 - that area can be leeward or provide a windbreak saving carrying yet more junk against your allowable payload, 3 - enhance the vista from the lounge without looking out on an inside of an awning π π
I'm sure there are more noxious odours permeating a caravan after a night on the booze and curry, within the caravan than outside in the open from the cadac π π
