- May 30, 2007
- 1
- 0
- 0
we have a renault scenic authentique 1400 petrol and would love to start caravaning but have been told cant because car too small,can anyone advise us if this is correct?
thank you
margaret
thank you
margaret
of course i should have said - the m.t.p.l.m. weight of the van should not exceed 85% of the kerb weight of the towing vehicle especially and even more so if you are new to the game. incidentally the mtplm weight is usually stamped on a small aluminium type plate adjacent to the van door (ground level generally) and before you ask mtplm means maximum technical permissable laden mass i.e. your van plus the recommended (in van's handbook) weight allowances for optional and personal kit. exceed at your peril. happy caravanning..................margaret, it all depends on two things - or rather three. 1st is are you prepared to tow or take the course? 2nd, what is the kerb weight of your car - the scenic is a punchy little beast so should strut its stuff, depending on the caravan and what you take in it. 3rd, as i mentioned earlier in (2), your caravan should, to be safe on the road and easiest for you and the car to handle, be no heavier than 85% of the car kerb weight. this isnt hard to calculate if you know all the relevent weights. hope this helps a little
