Car Air Con
2,400
I wrote elsewhere on the forum that I considered upgrading my 2009 Mk1 Kia Sorento tow car.
It drives and tows well, but the air con / climate control had stopped working which made longer motorway trips rather noisy and a bit uncomfortable because of the need to have the drivers window open to cut down on the heat inside.
I took the Sorento to a tyre and exhaust place that regassed vehicle aircon last year but the fitter said that he couldn't do the job because of a leak in the system.
I found a local aircon specialist workshop today, after forgetting about getting the aircon tested for almost a year and he pressure tested the system and reported that there was no leak.
The aircon guy said that there might be a very slow leak, so he added the gas and some dye to my aircon system and told me to use it as often as possible.
If there turns out to be a serious leak they will investigate further.
It was a blissfully cool drive home, aircon on, windows shut.
Today's aircon technician mentioned that the valves were a bit awkward to get to under the bonnet, and I can't help wondering whether the less experienced fitter from last year took a look, decided that the job was too fiddly for him to bother with and reported a leak?
We're off to St Ives again at the end of this month, and if the aircon is still working properly during the long tow down I'll be a happy man. 😅
4,334
C:sweatsmile::sweatsmile:L man!!!
There are numerous seals in an AC unit and if the AC is not used regularly some seals can begin to dry out and leak.
If that's all that happened, then sometimes regassing the system floods it with the new fluid and it can sometime regenerate them enough to make them work.
Just make sure you use it regularly.
The big problem can arise if the pipes have separated enough to allow debris into them. This contaminates the system and can involve major work to flush out repair and ragas.
Reactions: Parksy
2,665
I just leave mine on all the time. (Unless Windows are open, which is about never). Just a nicer atmosphere. Car is now in its eighth year, I think I will get it topped up soon, it gives it a boost.
2,400
The technician today said that if the aircon continues to work, take it back every 18 months for a re-gas.
The problem might have started because I have a Fiesta runabout for local journeys, so the seals might have dried out on the Sorento.
Because the majority of our groceries are delivered now and my granddaughter has changed schools so I no longer collect her, I might sell the Fiesta instead.
Jul 15, 2008
3,899
1,084
.......regular regasing to check the level is best practice as is regular ocasional use throughout the year.
Keeps everything lubricated.
I have been told that if the level gets too low most systems shut down to protect components.
Reactions: Dustydog and Parksy
May 24, 2014
3,687
765
On my wifes Volvo, the aircon rad is mounted very low at the front of the car and is hit by nearly every stone that gets thrown up. Eventually the aircon lost its ability to chill, and we had it regassed, only for it to revert to type in a couple of days. Eventually we had the rad replaced and car regassed again, £200 all in. Been in it all day today after its been stood for nearly 18 months, only very occasional short journeys and the aicon is still tickety boo.
Reactions: Parksy
2,400
For a pressure test, re-gas and dye I paid fifty quid.
The more I think about it, the more I feel that the initial failure on the Sorento was due to lack of use.
I've used the Sorento more recently because the auto gearbox is easier on my sciatica than the manual Fiesta.
Which reminds me, I haven't used the Fiesta for about a month.
I must run the aircon on the Ford in the morning 🤯
2,575
From day one i use the air con on my car and it was checked last Monday it got go back to have a air con service end of this month if it needs to re gas we have it done.
Reactions: Parksy
Oct 8, 2006
2,041
720
Just remember that under normal use the air-con will increase your fuel consumption by about 3-5mpg.
2,400
That's true Woodentop, but on a long tow on a warm day it's worth it for us.
I'm not one for detailed conversation when I'm driving, but with the air con keeping us cool and the car windows shut at least I'll be able to hear when Herself says something, without losing concentration through straining to hear over the ambient motorway noise when I'm towing.
2,665
About 1 to 1.5 is normally quoted. And around my findings. But small engined cars seem more adversely affected.
But the benefits out way the negatives IMO. Years ago, aircon was marketed as a safety feature. You don’t seem to hear that now.
5,252
Our Jeep will be 9 years old at end of year and I doubt if it has ever been re-gassed. I have had it 3 years and have not re-gassed it. Our Corolla is 26 years old and there is no record of it ever having been re-gassed and air con works perfectly. I think I have only had to re-gas an air con system once and that was over 30 years ago!
Oct 17, 2010
1,320
565
19,435
My air con is on auto all the while, summer or winter, never switched off.
Apart from increasing fuel consumption A/C also eats into your horse power.
Anybody any idea how much?
2,665
We had a car a short while ago and I thought the air-con was fine. A local place had a great deal on so I got it done. France was very hot that year and the improvement was marked.
2,665
Air-con switches on and off. In my car you can’t tell it’s happened and it feels no different. But logically some power is used.
On low powered cars you feel a jar when it comes on and really feel the difference. I know of people that turn the air-con off to go up a hill.
So HP used as a percentage of HP available will be very different.
1,320
565
19,435
The only indication I have is the increased in air flow at the start of a journey, either cooling or warming,
9,070
BTW what is the difference between air conditioning and climate control?
Air con you have to turn the controls and it doesn’t self adjust. ACC automatic climate control is self adjusting around the set temperature and will normally self select recirc mode if required.
Reactions: JezzerB
4,334
Leaving the car windows open increases fuel consumption more than using AC would.
Air is colder too !
That has a lot variables and it can go either way depending on how wide open your windows are, how many are open and how fast you are going
This also has a lot of variables. When you turn the AC on you are only telling it you want it to cool. but it has operating limits just like a fridge and once the AC system is cool enough it stops using power until it has warmed up a little. How quickly this occurs is dependant on how much heat you are asking it to move.
How it affects fuels consumption and available power for driving depends on the rating of the unit. I have seen quite a range of quoted power consumptions for car AC units from as little as 3kw (4hp) to 15kW (20Hp) How that impacts fuel consumption is difficult to calculate, becasue the AC usually does not use power all the time.
I am sure it would be more noticable in a high mpg small car than a bigger lower mpg vehicle.
AC is simple the unit that transfers heat. It has a secondary function of being able to remove humidity.
Climate control is an over all system that measures the "climate" (usually temperature and humidity) and decides whether to add or remove heat and sometimes to add heat as well as trying to remove humidity at the same time. They often also have some automation of which outlets to use in the car
Reactions: Dustydog and DaveA1
2,400
My Kia has climate control that will maintain the temperature dialed in, but when it's turned down to mininum temperature it is air conditioning.
There's never been any problem with warming the car interior, the heating side of the climate control has always been very good.
We get properly cooled air now with the re-gas.
2,575
I hope it gives plenty of cool air now after the re-gas and for many years to come;)
Reactions: Parksy
