Caravan alarm
Jun 15, 2018
Hi, I'm new to the forum and have purchased a Elddis 550 Osprey a few months ago. Can any one recommend a decent alarm that I could fit to this van.
Paul
4,136
Hello Paul,
The first thing to check is your caravan insurance policy that might have particular requirements. IF you don't follow what your insurer says, it may invalidate your policy.
1,818
I cannot suggest an alarm as I have not had to fit one but insurers will accept most makes and give you a discount. Do be aware though that alarms will run the battery down fairly quickly if the caravan is not connected to the mains, probably you would get no more than two weeks out of a charged battery. If it is in store or there is no mains connection then a good solar panel will be needed, but that needs a regulator to prevent overcharging..
936
ProfJohnL said:
Hello Paul,
I have never ever found an insurance company that will invalidate a policy because an alarm Has been fitted !!!
May 24, 2014
3,687
765
If the caravan was manufactured without an alarm, there is not going to be an issue with an insurance company over the type or make of alarm fitted........................unless
Unless you have negotiated or accepted a discount from your insuance company in which case it would need to be type approved.
