Before I unhitch I apply the caravan brakes. If I then push the caravan backwards the brake handle rises and the caravan moves a small amount then stops. My dealer tells me all is well with the brakes because it stops when you push it backwards. All good. But if I engage the motor mover, it won't move the caravan forwards but it will move the caravan backwards. . To my mind this is clearly wrong.
I do know what the problem is but surely the brakes should not allow a caravan to be moved backwards under the power of a motor mover.
Any comments from the experts before I pursue this further with my dealer?
If I reverse onto a pitch, or my driveway for storage, I always go back further than needed, and then forward again a couple of feet. When reversing, the brakes disengage. In modern caravans, they are only meant to work going forward otherwise you wouldn't be able to reverse. older caravans, without automatic brakes required you to block the hitch from compressing. They, in effect, worked both forwards and in reverse.
I suspect that the caravan moving a small backwards amount is the brake shoes dragging, but not the brakes actually engaging. They cant until moved forward to reset them. Reversing with the vehicle disengages the brakes.
A motor mover will easily push a caravan back with what is in effect, dragging non applied brakes.
Trying to move it forward on a mover with the handbrake on, will engage or reset the brakes almost immediately.
You can then use the mover to fine tune your pitch position. The mover won't disconnect the brakes. Its the backwards movement of the hitch that does that only.
Anyone that has manually adjust old drum brakes in cars will understand. You always just wanted a slight scuffing noise to be heard.
Sometimes you will hear a slight scuffing sound from the caravan brakes in reverse, although difficult over mover noise.
Unless you move a small distance forward after a reverse, your brakes are in effect, not actually working as they should.
Try reversing with the car. Put the caravan handbrake on and try reversing again. not too hard.
Now release the handbrake and drive forward a couple of feet. Apply the caravan brake and try to move forward.
A LOT harder as the brakes have properly engaged.
Nearly forgot. Applying the caravan handbrake with out moving forward first to reset brakes will damage the handbrake operation in time.
