Caravan Club TV connection
I have just booked a few nights on the New Forest CC site. They have a Television connection on the hook up pole.
I normally use a dish and freesat box.
Question 1
If I use my Satelite cable with the F connectors, what type of connector do I need to connect to the site.
I will use the outside Satelite connector to go into the Van.
Question 2 Do I connect straight into the TV using another connector from the Satelite if so which one?
Question 3 Can I connect into the Freesat box in the usual way
Question 3 The other option is do I just continue to use my dish and Freesat box.
Les
If it is the usual CC arrangement,it will be digital from the hook up for freeview,you will need a digital co axial cable,from the EHU post either to the co axial point on the outside of your van and then a short co axial cable from the socket in your van to the back of your TV,or you could conect straight to the back of the TV but the lead would need to come in through a window,I think your satellite connections will be different from the EHU connection,so may be easier for you to use your satellite dish.Most of the sites in the New Forest have trees that obstruct some satellite signals,so you may need to choose your pitch with care.
My connection in the Battery box needs an F connector, which means inside the Van I need to use my F connector, is there a connector that I can fix to the F connector then straight into the TV?
I believe that the connection on the EHU pole is the same as the back of my TV.
Les
Still being good!!!!!!
