Assuming that the fridge will not light, apart from a few basic checks, there is not a lot you can do apart from have the fridge checked by your dealer/service point.
1) Do other appliances function ok on gas?
2) have you tried turning the gas supply isolator for the fridge to it''s alternative position?
3) Have you tried turning off the gas at the bottle, then holding in the gas control knob on the fridge, while it's in the "ignite" position to dispel any build up of gas, as an incorrect gas/air mixture will cause problems?
Wait a few minutes then retry lighting the fridge.
If you have a small window to see the gas flame, can you see a spark when you try to ignite the gas, if not, the piezo ignition may have failed. If it is automatic ignition, can you check the 12V supply to the fridge? if it is manual igition, pressing the ignite button should produce the spark. No spark indicates to much gas or failed ignition unit.
4) Are all external fridge vents clear? once again, a blockage could cause problems.
Apart from these basic checks, it is advisable to contact your dealer as only Gas Safe registered persons may work on the gas supply..
REMEMBER, IF YOU SMELL GAS IN THE VAN, DO NOT TOUCH ANY ELECTRICAL SWITCHES, TURN OFF THE GAS AT THE BOTTLE TAP AND VENTILATE THE CARAVAN BEFORE MOVING IT.
Hope this helps.
Regards,
Brianjw47.
