caravan jack
Sep 25, 2009
372
Thanks Sprocket - I think I will invest in one. Must admit the last puncture I had was in 1982! (I remember it well because it was the only time my parents came to France with us and my dad had just turned 60!!). I can't remember how I changed the wheel then but I know I have been risking it ever since!!! Must have been extremely lucky, but I have always looked after my tyres.
Keith
Hello Keith,
As per Joby's post, Halfords at
Sep 25, 2009
372
Keith
Hello Ken,
As per Joby's post, Halfords is the place to buy at
G
Guest
The one thing to bear in mind is that regardless of which jack type you use, the footprint of the jack is important. Many of them have relatively small footprints and although they will work fine on tarmac, on a grassy verge they could be unstable.
The trolley jack has the advantage of having a large stable footprint and so will work een on an uneven surface, which is where you are likely to be in the event of a breakdown as you do not wish to try and change a wheel in the lane of a motorway, do you?
I use a 2 tonne trolley jack from Machinemart which has its own case for carrying. Yes, it is a bit heavier but sits at the back of the boot and can also be used for the car.
However, if you fancy a device similar to Reg's then Riversway Leisure are selling the identical thing at a discount price, or so they say.
May 15, 2007
471
Graham they are next to useless.I have 2,the cast alloy feet tend to break off,the supplied brackets bend easily causing the jack to slip off, If the lack is less than half extended the fuse blows They are 1 Tonn rated but are not capable of lifting my 1350 kg van
Thanks for that Tony , ill give that one a miss
4,465
Buy a 2 ton trolley jack from Halfords , Machine Mart, Aldi etc.
John L,
The standard Al-ko scissor jack supplied with TA caravans on Al-ko chassis is a waste of time. I challenge anyone to use it :-
1. Successfully lifting both wheels
2. Without sweating
3. Without blisters
4. And that's if you can actually summon the strength to turn the handle.
I challen0ged Al-ko two years ago to get one of their ladies to demonstrate. Guess what , no response. It just doesn't work!
Cheers
Dustydog
Hi dusty,
I wasn't advocating a particular make of jack, jut the safest design principal. Cheap hydraulics (even some expensive ones also) cannot be trusted over long periods, in case the stop valve leaks or the system springs a leak some where in which case the jack will collapse without intervention to stop it.
That simply cannot happen with a screw jack of adequate capacity.
Mar 26, 2008
873
As a lady who tows solo quite often I wouldn't have any of the jacks here as first choice.
All of our caravanning group have airbag "Easy-Lift" style jacks as first choice.
They are light in weight and compact. No physical effort needed to opperate as they work off the car exhaust and will lift any caravan that has sunk into mud or sand with ease.
Draper sell a reasonably priced version.
Nov 4, 2004
1,191
Do you put something on the top of the inflatable bag so it pushes against the metal frame?I was advised not to use this type of jack on a caravan as it inflates around the frame and actually pushes the van up against the floor,
Mar 26, 2008
873
Placing the air bag under the chassis member and axle does no damage at all.
On a car trailer with the bag just under chassis member by the time the bag inflates enough to lift, the bag is filling out and comes no where near the floor.
You might damage your caravan with any jack used without thought!
My friend had the air bag and now has the Kojack
He had a problem attaching to his Mondeo exhaust
One man's meat etc
Engaging brain is always adviseable
Do they use them for van levelling or lining up the Alko wheel clamp?
May 21, 2008
2,463
I use a small bottle jack from machine mart. I've got a simlar idea to reg's under our van to captivate the jack piston.
We carry some 10x2" timber for levelling and this doubles up as base pads for the jack.
If the van is too low to get the jack under, just use the timber under the deflated wheel to gain height. I would never re-use a tyre that has gone flat while in motion as there would be significant weakening of the side wall, so dragging it up a couple of 2" timbers won't do any harm.
Also remember to put the steadys down while changing the wheel just in case.
Finally have a practice run at changing a wheel at home before you do one for real. You'll work out a plan of attack then before you have to do a real one in the rain at night. Trust me it's guaranteed to rain just when you could do with out it (sods law).
Steve L.
4,465
Steve L.
Good advice
Steve L.
Alko recommend attachment to the car as well top be on the safe side
Mar 10, 2006
3,274
47
Thanks for the riverside link, i have ordered the jack today, the spec is the same as the kojacklite, apart from max lift which is 10mm less.
May 15, 2007
471
Hi i have beel looking to find this air bag on the net, any odea where i can find it , or what doesc it come under in drapers web site
cheers
graham
Nov 27, 2009
114
Well that's good service.
2 tonne trolley jack complete with plastic case that I ordered off an ebay seller on Tuesday night arrived today special delivery.
Mar 26, 2008
873
One man's meat etc
With Air bag jacks you should get attachments to fit twin exhausts or block linked exhausts.
I would struggle with regular jacks, the air bag lifted a caravan out of a soft muddy roadside verge. Our friends pulled onto whay seemed to be firm ground when a tyre puncture. No regular jack would work, air bag lifted it easily
