- Mar 10, 2006
- 3,274
- 47
- 20,685
Hello Keith,Thanks Sprocket - I think I will invest in one. Must admit the last puncture I had was in 1982! (I remember it well because it was the only time my parents came to France with us and my dad had just turned 60!!). I can't remember how I changed the wheel then but I know I have been risking it ever since!!! Must have been extremely lucky, but I have always looked after my tyres.
Keith
Hello Ken,Thanks Sprocket - I think I will invest in one. Must admit the last puncture I had was in 1982! (I remember it well because it was the only time my parents came to France with us and my dad had just turned 60!!). I can't remember how I changed the wheel then but I know I have been risking it ever since!!! Must have been extremely lucky, but I have always looked after my tyres.
Keith
Thanks for that Tony , ill give that one a missGraham they are next to useless.I have 2,the cast alloy feet tend to break off,the supplied brackets bend easily causing the jack to slip off, If the lack is less than half extended the fuse blows They are 1 Tonn rated but are not capable of lifting my 1350 kg van
Hi dusty,Buy a 2 ton trolley jack from Halfords , Machine Mart, Aldi etc.
John L,
The standard Al-ko scissor jack supplied with TA caravans on Al-ko chassis is a waste of time. I challenge anyone to use it :-
1. Successfully lifting both wheels
2. Without sweating
3. Without blisters
4. And that's if you can actually summon the strength to turn the handle.
I challen0ged Al-ko two years ago to get one of their ladies to demonstrate. Guess what , no response. It just doesn't work!
Dustydog
Engaging brain is always adviseablePlacing the air bag under the chassis member and axle does no damage at all.
On a car trailer with the bag just under chassis member by the time the bag inflates enough to lift, the bag is filling out and comes no where near the floor.
You might damage your caravan with any jack used without thought!
Do they use them for van levelling or lining up the Alko wheel clamp?As a lady who tows solo quite often I wouldn't have any of the jacks here as first choice.
All of our caravanning group have airbag "Easy-Lift" style jacks as first choice.
They are light in weight and compact. No physical effort needed to opperate as they work off the car exhaust and will lift any caravan that has sunk into mud or sand with ease.
Draper sell a reasonably priced version.
Good adviceI use a small bottle jack from machine mart. I've got a simlar idea to reg's under our van to captivate the jack piston.
We carry some 10x2" timber for levelling and this doubles up as base pads for the jack.
If the van is too low to get the jack under, just use the timber under the deflated wheel to gain height. I would never re-use a tyre that has gone flat while in motion as there would be significant weakening of the side wall, so dragging it up a couple of 2" timbers won't do any harm.
Also remember to put the steadys down while changing the wheel just in case.
Finally have a practice run at changing a wheel at home before you do one for real. You'll work out a plan of attack then before you have to do a real one in the rain at night. Trust me it's guaranteed to rain just when you could do with out it (sods law).
Steve L.
Alko recommend attachment to the car as well top be on the safe sideI use a small bottle jack from machine mart. I've got a simlar idea to reg's under our van to captivate the jack piston.
Steve L.
Hi i have beel looking to find this air bag on the net, any odea where i can find it , or what doesc it come under in drapers web siteAs a lady who tows solo quite often I wouldn't have any of the jacks here as first choice.
With Air bag jacks you should get attachments to fit twin exhausts or block linked exhausts.My friend had the air bag and now has the Kojack
He had a problem attaching to his Mondeo exhaust
One man's meat etc
Well that's good service.
2 tonne trolley jack complete with plastic case that I ordered off an ebay seller on Tuesday night arrived today special delivery.
