Why? you can't lift much more than 50% of the gross weight at a time. AL-KO side lift jack is rated 800KG to use on vans up to a maximum of 1600KG.HALFORDS HAVE A DEAL ON TROLLEY JACK, A 1TON MIGHT JUST NOT BE GOOD ENOUGH,HOW HEAVY IS YOUR VAN WHEN FULLY LADEN??THE TWO TON JACKS ARE A SIMILAR SIZE,ITS NO GOOD TRYING TO LIFT A 11/2 TON CARAVAN WITH A 1 TON JACK??
thats why i asked the weight of his van fully laden,it could have been a heavy vanWhy? you can't lift much more than 50% of the gross weight at a time. AL-KO side lift jack is rated 800KG to use on vans up to a maximum of 1600KG.
Join the CC or C & CC roadside assistance options and the nice man will do it all for you. This especially better if you get a puncture on the motorway as those big trucks seem to delight in seeing how close that can come to your broken down unit or so it seems!A trolley jack is ideal when at home but they are quite heavy to tow around with the setup.
I carry a bottle jack and you are correct in stating that when the tyre is flat the chassis is too low for the jack, I have welded up a bracket for each side of my caravan which bolts through exisiting holes just in front of the axle, each side has a plate with a location cup for the jack top welded on to the upright at a level to allow the bottle jack to fit if the tyre is flat.
Luckily I have never had to use my bottle jack but am prepared for a flat tyre change if required.
