Caravan movers
Jun 9, 2014
I have just read on your forum about the Powertouch Evo mover and not too sure about this disengaging bit. How do members think it compares with the Truma SE R? I need to buy a mover as I am getting on a bit and have a bad back and want to get the best one. Thanks.
Feb 3, 2008
3,790
To Haymarket Techies
Please could "New members - say hello" be moved off the top of the Index List so it's not inundated with technical questions by default? :huh:
2,399
Don't worry about it WC, the topic can easily be moved to a more suitable message board by moderators, it's no problem. The new members message board is at the top of the forum page for a reason, it's so that new forum members see it first.
3,597
Hi Trish
Both Truma and Powertouch are excellent quality movers. They can be purchased with electrical engagement. They are not the cheapest but the guarantees and back up are second to none.
The new top of the range Truma XT is almost £2,000 but has loads of user friendly gizmos.
40
Electric engagement souns a good idea, but it's more expensive and complicated, and on some models the engagement drive projects forward some way from the main mover and can get damaged if crossing kerbs, speed bumps etc.
If you find the manual engagement getting a bit hard, conside removing the cross shaft if one is fitted. This way you only fight with one set of return springs at a time. Get the longest handle you can find to increase the lever ratio, or delegate the task to the OH.
