Caravan not draining
Oct 20, 2022
117
45
4,585
Hi,
caravan is not draining when we pack up,we have a lunar 574 with truma combi heater.
I presume it is either the yellow drain valve or the drain valve on the truma heater.
is there anyway of testing to see which one it is
cheers kb
Jan 19, 2002
1,711
551
I would presume it is the yellow drain tap in the 'up' position then open all the taps to between hot and cold and let gravity do the rest!
I might be over-cautious but I always allow the hot water heater to cool before draining and setting off. - and in any event it saves any scorching if on a grass pitch!
2,810
They often do not empty 100%. You can leave the drain tap or taps open-while towing, this helps with the rest.
117
45
4,585
When I put the drain valve in the up position and the taps open it doesn’t drain
2,391
In a previous van, the yellow drain valve was a bit tetchy. You had to move it slowly and you would find a bite point at which it would drain. Had to hold it there until it drained. Don’t know what the problem was but as there was a workable solution I lived with it.
mel
1,711
551
Hope it’s just blocked and can be easily remedied for you - googled a replacement and found them to be getting on for £45!
5,587
I’ve had a stuck yellow valve. With the lever up tap the side of the body with a small hammer. May work.
5,505
Thanks everyone,tried opening taps and draining ok,never did this before though
This should be done every time the caravan is put into storage especially over the winter when water in the pipes can freeze and burst a pipe or damage a tap.
2,697
Some years ago we forgot to lift the taps up on the sink and the Shower on our caravan in storage in winter but never again because we had a problem with the shower it had to be replaced
4,846
I tend to blow through the water system in the winter after each time out it takes about 15 minutes but will save having a pipe bursting .
5,505
Yep we do the same using the shower tube. I know I have a big mouth, but I do remove the shower head first! :ROFLMAO: :ROFLMAO: :ROFLMAO:
  • Haha
Reactions: Challenger
Jan 8, 2006
264
6
18,685
Hi,
cheers kb
Mine is exactly the same it won’t drain unless when I open the drain tap then immediately open the kitchen hot tap. Done it from new. Lunar Quasar.
5,505
Mine is exactly the same it won’t drain unless when I open the dra tap then immediately open the kitchen hot tap. Done it from new. Lunar Quasar.
You need to open the taps on hot to drain boiler otherwise a vacuum could form making emptying the boiler a long wait.
4,473
Basically open everything. You have to allow air in to allow gravity to pull the water out. In some systems, depending on how the caravan manufacturer designs the layout, it helps to either blow air through the taps, or to suck at the drain points. There are kits to help do this.
Reactions: J.Lo
