caravan painting
whilst I know people get cars sprayed every day, how common is giving the caravan a freshen up - paint wise, mine has that dated faded off white colour, any idea how much this would cost....
Did my old sprite vintage 1979 with a roller and gloss good etch primer, then couple coats of gloss on top, lambs wool roller gave it a ripple effect, looked ok spose depends on how old ya van is ?.
if its just fadeed get some t-cut and rub it well in till it starts to go black then wipe it off its hard work but it works dont forget to use a good wax polish after the front of our 2005 abbey fades and this works well for me
BE VERY CAREFUL with "T" cut as the paint on the van's is nowhere as thick as what gets put onto a car:
Caravan paint thickness = 23 (+/- 3) microns
caravan paint thickness
Car paint can vary from 90 microns to 180 microns depending on manufacture & can be even thicker !
sproket your information boggles me if i did not know t cut would work i would not recomend it i paint cars and caravans after accedents this will work but you must use common sence as with everythig else hope you do not take this as an insult because its not intended as such
No problem !
Not every body knows what "T" cut will do, in the right hands & someone who knows what they are doing it's excellent, as you say you do it for a living....
All i am doing is making them aware of how thin the paint is
