Caravan Paintwork.
Apr 1, 2010
24
I have an Ace Award Tristar (2007) and the front panel(GRP) is turning yellow on the corners of the change of section - ie around the grab handles, side light, gas bottle lid etc.It appears like yellow lines.
Obviously this has been happening over a period of time - but thought I would get it sorted when serviced before the 3 year warranty ran out,as have been told that the original paint thickness was insufficient.
However - Swift only give 12 months warranty on paint!!(and a load of other things are exempted after the first year) and do not want to know.
Has anyone else had a paint problem with their front panel?.
It is not fading by the sun/weather.Can the external surface be re-painted?
Jan 11, 2009
127
Hi Graham, i was just about to post on the same topic!
I have a 2005 Geist, and the GRP on the front is starting to yellow on the edges, i have seen some posts about people having the fronts re laquered, i was wandering is there a polish or treatment that can be used, i seem to recall an Autoglym product called "Resin Treatment?"
Jan 14, 2009
53
i had a dulling/yellowing front panel on my 2002 compass and used farleca gel coat restorer (after being told about it on here) and its brilliant!!!
i used all types of autoglymn/megs products with next to no results
used the gel coat restorer back to bright white with good shine again
not the easiest polish to use but great results then wax/top coat polish over the top for protection
easyer to find in boat chandlers as its a marine product tho
rob
Apr 1, 2010
24
rob
Hi,Steve,
thanks for your reply- similar to yourself - it is not an 'all-over'problem just yellow lines appearing on the edges of the places where fitments are attached.
I will look out for the 'Resin Treatment' as I will try anything to remove them!!
Graham.
Jan 11, 2009
127
rob
Thanks Rob, will have a look at this
Apr 1, 2010
24
Hi,Steve,
Could you please let me know what is the website that you used for the Farleca Gel Coat Restore that Rob suggested.
Sounds good - following this topic with interest!!
Graham
Jan 11, 2009
127
Stuff arrived, used and ........ did exactly as it said, bit of elbow grease required, but just the job!
Apr 1, 2010
24
Steve,
Was it 'Yachticon Yellow Stain Remover'?
I have had difficulty in finding your link but thought it might be the right stuff -in a white bottle!!
Jan 11, 2009
127
Graham, this is the link,
www.nauticalproducts.co.uk/shop/product.php?productid=352&cat=4&page=1
Jan 14, 2009
53
sorry for my late reply here lol
but as you found it just needs more elbow grease than a conventional car polish does
did you apply a top coat wax to protect your panel after using the gel coat restorer?
i used a meguires carnuba wax and still very very good shine on it
rob
Apr 1, 2010
24
Hi,Steve & Rob,
I received yesterday my 'Farecla Marine Gel Coat Restorer & Wax'.
Just tried it now on one of the yellow 'bits' on the front panel.
Brilliant!! back to white and leaves a good shine.
Now I have the whole panel to do!!
Thank you all for the help/advice - greatly appreciated.
Graham.
Steve,
Forget about the previous note about Yellow stain remover -that was for something else!
Could not follow your exact link - but got onto 'Bosun's Locker' from your link - somehow - and ordered the Gel Coat Restorer from them. (
Jan 11, 2009
127
rob
Yes thanks, waxed it, even had a sunny day to do it on!
Jan 11, 2009
127
Hi,Steve & Rob,
Graham.
Steve,
