Caravan shock absorbers
Nov 9, 2009
170
What are the benefits ?
I have a 3 year old twin axle Bailey without them - the latest versions all have them as standard as i was wondering what real benefits they bring and if so would it be worth fitting them to mine?
Andy
940
Shock absorbers help towards stability and reduce pitching and general "twitchiness" of the outfit. They are well worth the relatively modest outlay.
Mar 10, 2006
3,274
47
Andy
I would say that ALL caravans in the UK, should have dampers fitted, the roads are now so bad, the shockers will reduce the caravan from bouncing so much, having said that maybe the single axle would benefit more?
Feb 27, 2010
633
when i collected my new Swift ( with shocks) last November the difference between towing it and the old one was very noticeable.
The whole outfit "bounced" less than the old van , and is much more stable. Handling is much improved and the whole outfit feels rock solid.
If you can retrofit shocks ....do it.
Nov 9, 2009
170
Thanks everyone - I assume the fixing points are on the chassis -I guess i need to talk to Alko?
cheers
Andy
