Afternoon all. We picked up our new (and first) caravan last week. Spent this weekend living in it testing everything out.
Im not sure if this is normal, or its a problem somewhere but the shower is dreadful. if you hold it at waste height, with the head at 90 degrees, it works, as soon as you lift it to head height, the water just stops coming through the head and it seeps through a couple of little holes at the base of the handle.
Actually, if you tilt the head at any height. the water stops and trickles through these holes. (I was told that the holes are there delibratly to drain the water from the shower head!?
Im not sure if its a pressure problem? (Its a 24 foot van but the shower is located at the mid point)
As it currently stands, its pretty unusable as a shower. (You cant even wash the shower with it) Tried it on electrical mains hookup. The water makes it way by virtue of a 'Truma' water pump. that pulls through from the barrel outside.
I was just wondering:
Is this is normal?
Do I need a stronger pump?
Is there is a leak somewhere in the system thats dropping the pressure? (How would i know?)
Your feedback i most welcomed!
Is this is normal?
