milenco wheel lock question
Have fitted a milenco wraith wheel lock to van. I removed 1 wheel stud and replaced it with milenco wheelbolt receiver, as per instructions, put on lock and all is fine.
Question is do i leave the wheelbolt receiver in place when towing or do i put original wheel stud back on?
Thanks In Advance.
We have the nemisis so a similar set up and I can confirm yes you leave the receiver bolt on
Just remember to torque the receiver bolt up and also when you have it serviced put the original bolt back on or leave the service engineer the receiver key ๐Ÿ‘
