Caravan Stay Lubrication. (or corner steadies)
White ptfe loaded grease( Soudal), On another forum an experienced member has suggested Wurth HHS 2000 high pressure adhesive synthetic lubricating oil , so I be trying that on the next set I do.
1. Grease
2. It stops the threads rusting, and makes them smooth to operate.
I get to look at a lot of steadies and if you use general purpose grease ( which I have done in the past), you need to wipe the old stuff off the threads first ( wire brush then brake cleaner) as it will have collected all sorts of 'stuff' off the roads including grit which when mixed with grease makes grinding paste. The threads are quite coarse and a square profile so will survive a lot of abuse, but why push it..
Some don't come with a sliding plate and just use the trailer rear arms and underside of the caravan floor for the sliding nut to move against, so a quick squirt of grease on those parts will also ease the movement
My comments were made tongue in cheek, I couldn't insert a rolling eyes emoji because for some bizarre reason they are all greyed out on my tablet
You'd be surprised , I see a lot with great wadges (technical term!) of old grease encrusted with grit and lumps, tar and straw either side the working part of the screw thread.
