- May 7, 2008
- 121
- 0
- 18,580
i'm afraid that i have to say that i am disappointed with Skoda winning towcar of the year. we tow with a Citroen C5 estate 2.2 diesel (similar to the one tested in the same catagory as the Skoda) and the caravan club testers thought it was a great towcar, but put it down for 'lack of information in the owners handbook'.
let me explain: caravan testers were confused, saying that there was no advice on what setting to have the Hydractive suspension on when towing. the NORMAL setting is the answer. when a weight is loaded in the C5 it returns to a level point. so, once hitched up, basically the suspension sets itself up to cope with the weight.
may i now move onto the party piece. on C5 estates there is a little button in the boot which raises and lowers the rear end of the car. this is to make boot loading easier. but it also makes hitching up effortless. all we do is position the caravan coupling head over the towball (via the motormover) and raise the rear suspension until it hitches up; no messing about with the jockey wheel. also, this facility can only be used when the engine is off, so no noise when hitching up on those early morning trips.
it isn't just the suspension. the 2.2 ltr diesel engine is great for towing- it just keeps on going! it is also very economical. we get around 45-50 mpg solo at 50mph! and around 30-35 mpg at 50mph towing. one more point: the Skoda was tested in dry conditions and the C5 in wet.
ok, maybe the skoda was cheaper to run. i just wanted to defend Citroen! ok, rant over!
