Caravan Truma Carver Crystal 3 Water Inlet Filter Housing
Jul 5, 2023
Hi everyone took our new to us caravan out a couple of weekends ago, we had a blast loved it it’s a 1999 Abi celebration. I did notice our water inlet housing clips have snapped off we’re the pump fits in to the caravan so when the water system is pressurised it works loose, so have been looking online for a replacement with no luck. Does anyone know of a filter housing that will fit exactly we’re the
Caravan Truma Carver Crystal 3 Water Inlet Filter Housing as to replace this item with one that is not discontinued thanks. The one we have now, the pump plugs in and you fit a blue plastic box type thing above where the submersible pump plugs in to the housing. If possible I would like to use the same pump in the new inlet if possible. Just not sure what part will fit perfectly new to caravaning thanks again.​
4,628
We had our complete housing replaced with a later model Truma, but sadly you need to buy a new Truma pump with the trigger style connection. Well worth the costa s a lot less hassle. The new pump is about £50, but can be pickeed up second hand as I sold one last Saturday for £25.
Reactions: Wanderer2023
Jul 5, 2023
Thanks buckman just bought a Truma conversion kit comes with the water inlet and the pump head you have to rewire yourself I’ll see how that goes fingers crossed it the right fittings. Was 75 quid all in
1,669
514
A common replacement and I think you can still buy the clips for about 4.00 the pair at caravan shops and ebay
Jul 5, 2023
This is the only one I’ve found on the internet but it’s broke too. The little plastic clips are snapped so went with the conversion but there is a little bit of conflicted info online if the conversion will fit my caravan or not took a punt though because this inlet is discontinued has been since 2000 apparently
