Hi I have just bought a static green caravan 10' x 25'
No name printed on the side so I cant tell you the make
There is a gas pipe under the chasse
I have put a blue bottel on managed to get the gas heater to work but the gas lamps wont work
I have turned the tap on to full on all of them and there is no gas coming out and light it and no flame
I can even get the gas bottel off the hose conector with the tap off
I cant find any boiler I cant find any inlet from the outside nor any water pump so I have no sink toilet and shower
I cant find any waste tank drain pipe
I have found a main power inlet suplly that runs under the cassie of the caravan and goes into the wardrobe in the bed room whear the electric meter is but the wires are cut
I can find any 12V inlet supply
I have looked in all the cubords wardrobes and no water gas elecy supplies
Please could you tell me where all the tap and valves are
Many thanks
Batista230
Many thanks
Batista230
