ProfJohnL said:Hello Darranna,
The tow bikes will broadly balance each other out, But is does increase the caravans moment of inertia, so it will also be necessary to ensure that as much luggage and other items are loaded as close as possible to the axle to claim back some of the Yaw inertia.
How is it possible to "claim back some of the Yaw inertia" ?
Surely with masses distributed away from the centre of yaw the polar moment of inertia gained from that is there and adding mass anywhere else can never diminish that value, only add further to it?
Whilst vans are designed with end bathrooms with masses associated, it is misleading to compare this with concentrated quite high masses like e-bikes hung out over the rear body work.
The moment of inertia is ruled by the square of the displacement of the mass from the centre of yaw and here the bikes are out beyond the bodywork.
What increasing the polar moment of inertia will do is lower the natural frequency of yaw, that is fundamental, plus it makes encountering it and with it instability more likely. Bikes on the rear can be "tolerable" but never be as safe as without doing so.
