There could be several reasons why the electric side is not working but the most common is the 'kettle' plug mains connection has fallen out at the back!!
After that do all the lights work OK on the slide switch? they should come on in sequence and only one at a time.
If the lights are OK push the back temperature control slide to minimum and switch the front slider to half fan, now slide the temp control up to half way and listen for the click of a relay. Change to full fan and then push the back slider to full temperature and you should hear a second relay clicking in, there is a several second delay for this.
If that checks out OK then the control is working which leave either two faulty elements!! which is doubtful or the temperture sensor is faulty.
The howling noise you discribe is normal? it's a resonance set up by the heated air striking cold metal before it heats up the heat exchange. Some are worse than others but about a minute with the gas on full bore after being lit quietens mine down.
The good news is the mk2 fanmaster 4000 you have is really a 5500 Turbo? they assumed both gas and electric could not be used together as on the older mk1 fanmaster the electric side would switch itself off if the gas fire was lit as well.
